[postgis-users] convert sql table to xml by using java script
Bèrto ëd Sèra
berto.d.sera at gmail.com
Fri Sep 17 02:17:56 PDT 2010
Hi!
Before writing lots of code, you might want to see this:
http://www.postgresql.org/docs/current/static/functions-xml.html#FUNCTIONS-XML-PROCESSING
<http://www.postgresql.org/docs/current/static/functions-xml.html#FUNCTIONS-XML-PROCESSING>
Bèrto
On 17 September 2010 11:51, zhang zhe <luckyclare at hotmail.com> wrote:
> Hello,
> I want to convert postgres sql table to XML document automatically by using
> javascript code. For instance, if user open the URL,it will pop-up a window
> that allow user to save the XML file that converted from postgres
> table to any directory. I found some information from the Postgres home
> page, but it give only very general information.
> http://www.postgresql.org/docs/8.2/static/datatype-xml.html
> Does anyone has experience with this kinds of task. Is it possible to
> convert postgres table automatically to XML file.
> Thank you
> postgis-users mailing list
Constitution du 24 juin 1793 - Article 35. - Quand le gouvernement viole les
droits du peuple, l'insurrection est, pour le peuple et pour chaque portion
du peuple, le plus sacré des droits et le plus indispensable des devoirs.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100917/e97d970a/attachment.html>
