[postgis-users] Spatial queries using @ operator
Gastón Lucero
gaston.lucero at sitrack.com
Fri Sep 17 13:44:10 PDT 2010
Hello,i´m from argentina, so excuse my english.
My problem is i have a table with 500000 record,polygons and points type
and i have to find objects which intersects with an boundary in particular
Example of ,my query
select * from zone where geometry @ (select geometry from othertable
where id=1)
My table definition:
CREATE TABLE "zone"
zoneid integer NOT NULL DEFAULT nextval('zonas_id_seq'::regclass),
"name" text,
buffer integer,
description text,
layerid integer,
geometry geometry,
color integer,
CONSTRAINT zone_pk PRIMARY KEY (zoneid),
CONSTRAINT enforce_dims_geometry CHECK (st_ndims(geometry) = 2),
CONSTRAINT enforce_srid_geometry CHECK (st_srid(geometry) = 4326)
WITH (
OIDS=FALSE
ALTER TABLE "zone" OWNER TO postgres;
-- Index: idx_zone_geometry
-- DROP INDEX idx_zone_geometry;
CREATE INDEX idx_zone_geometry
ON "zone"
USING gist
(geometry);
-- Index: idx_zone_zoneid
-- DROP INDEX idx_zone_zoneid;
CREATE INDEX idx_zone_zoneid
ON "zone"
USING btree
(zoneid);
I have test of differents ways to accelerate my query with other
functions like st_distance,st_dwithin,etc
but do not know which to use
Thanks
Disclaimer:
This email and any attachments thereof may contain confidential, privileged, proprietary, or otherwise private information. This email is intended solely for the use of the individual to whom it is addressed. If you are not the intended recipient of the email and its attachments please inform the sender immediately and do not disclose the contents to any other person, use it for any purpose or store or copy the information in any way and delete this e-mail and its attachments from your system. Any views or opinions expressed are solely those of the author.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100917/ce45e70c/attachment.html>
