[postgis-users] How clip a line on many points
Andrea Peri
aperi2007 at gmail.com
Sun Sep 19 01:37:06 PDT 2010
I need to write a query sql where is need to split a line over many points.
I know the postgis 2.0.0 has the ST_Split(line,point),
but it work on 1 only point, not on MultiPoint.
So I can't use it directly.
The only think i can suppose to do is develope a ricorsive procedure
- write a procedure that using the ST_Split() can split a line over a point
output two lines and use this two lines to call again himself
on the remains points. -
But I have many perplexity because I don't know if is possible to write a
ricorsive method using the pgplsql, and this ricorsive method will be used
in a query sql.
And perhaps there is a more easy method.
Any hint and suggestion is welcome,
thx,
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100919/d5232a30/attachment.html>
