[postgis-users] combine serveral parts of the country
Ralf Suhr
Ralf.Suhr at itc-halle.de
Mon Sep 20 02:06:32 PDT 2010
Hi Chuchichäschtli,
you can use ogc_fid as primary key from your tables or create on schema for
one village.
What "Chuchichäschtli" mean in german?
Gr
Ralf
Am Montag 20 September 2010 09:34:11 schrieb Thomas Andres:
> Dear List,
> im Swiss and my English isnt the most best. Even, I will try the explain
> You my problem. Perhaps You will understand J
> In Switzerland the parts of the country were measured by different offices.
> The informations of the terrain (parcelles, rows, lakes, jungle etc
) are
> exchanged by Interlis Files (*.itf).
> With ogr2ogr this files can be imported into a Postgres Database.
> When You import only one file, its not a problem. Every Line, Point,
> Polygone and so on, has its own Feature-Id, which can be linked with
> another feature.
> I.e.: The geometry of a parcelle is linked with his number.
> Now, when I would like add a second village to my GIS, in the same
> Database, to be loaded in Mapserver with a mapfile layer
the parcelle
> with the same Feature ID will appear twice
so the link to the number of
> the parcelle is wrong
> What I made in a first time: after have imported the first village, I add
> to the primary and foreign keys, which I really Im going to use in my GIS
> a Char (a in example)
by using PostgreSQL
only after I imported the
> second file. This is a solution which works, but not for long time J
> I asked me, or better: I ask You, if there isnt a mechanism in PostGIS or
> PostgreSQL which is specially implemented for this kind of collage
Some
> kind of namespaces or
I dont know
You understand =-) ?
> Thänk You very much for Your help.
> Salutation from Chuchichäschtli
