[postgis-users] combine serveral parts of the country
Thomas Andres
andres85thomas at gmail.com
Wed Sep 22 00:15:49 PDT 2010
Salü Ralf,
Thank you for your answer.
- When I use ogc_fid as primary key, I cant import a second village,
because the IDs of their features were created by different offices,
different applications, so its possible that the same feature-id exists
twice.
- When I use shemas, I have to rewrite all SQL Querys. Select blabla
from village1.parcelles Union all select blabla from village2.parcelles
Union all etc
This can become very long J
If its possible, I would like that postgres sees, that the feature-id which
ogr2ogr is importing now, already exists,
so give to the new feature a new
feature-id, and at the same time he checks all foreign keys and adjust them
to the new feature-id to maintain the link. (J complicated)
Is there a easy solution?
Thank you for your help.
Salutation from Chuchichäschtli
P.S.: Chuchichäschtli is a box in the kitchen
Hi Chuchichäschtli,
you can use ogc_fid as primary key from your tables or create on schema for
one village.
What "Chuchichäschtli" mean in german?
Gr
Ralf
Am Montag 20 September 2010 09:34:11 schrieb Thomas Andres:
> Dear List,
> im Swiss and my English isnt the most best. Even, I will try the explain
> You my problem. Perhaps You will understand J
> In Switzerland the parts of the country were measured by different
offices.
> The informations of the terrain (parcelles, rows, lakes, jungle etc
) are
> exchanged by Interlis Files (*.itf).
> With ogr2ogr this files can be imported into a Postgres Database.
> When You import only one file, its not a problem. Every Line, Point,
> Polygone and so on, has its own Feature-Id, which can be linked with
> another feature.
> I.e.: The geometry of a parcelle is linked with his number.
> Now, when I would like add a second village to my GIS, in the same
> Database, to be loaded in Mapserver with a mapfile layer
the parcelle
> with the same Feature ID will appear twice
so the link to the number of
> the parcelle is wrong
> What I made in a first time: after have imported the first village, I add
> to the primary and foreign keys, which I really Im going to use in my
GIS
> a Char (a in example)
by using PostgreSQL
only after I imported the
> second file. This is a solution which works, but not for long time J
> I asked me, or better: I ask You, if there isnt a mechanism in PostGIS or
> PostgreSQL which is specially implemented for this kind of collage
Some
> kind of namespaces or
I dont know
You understand =-) ?
> Thänk You very much for Your help.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100922/0c435aba/attachment.html>
