[postgis-users] combine serveral parts of the country
Ralf Suhr
Ralf.Suhr at itc-halle.de
Wed Sep 22 02:27:37 PDT 2010
Hi Thomas,
ogc_fid can't exists twice. It is the primary key from ogr2ogr. Did you import
your secound dataset with ogr2ogr -append?
Gr
Ralf
Am Mittwoch 22 September 2010 09:15:49 schrieb Thomas Andres:
> Salü Ralf,
> Thank you for your answer.
> - When I use ogc_fid as primary key, I cant import a second village,
> because the IDs of their features were created by different offices,
> different applications, so its possible that the same feature-id exists
> twice.
> - When I use shemas, I have to rewrite all SQL Querys. Select blabla
> from village1.parcelles Union all select blabla from village2.parcelles
> Union all etc
This can become very long J
> If its possible, I would like that postgres sees, that the feature-id
> which ogr2ogr is importing now, already exists,
so give to the new
> feature a new feature-id, and at the same time he checks all foreign keys
> and adjust them to the new feature-id to maintain the link. (J
> complicated)
> Is there a easy solution?
> Thank you for your help.
> Salutation from Chuchichäschtli
> P.S.: Chuchichäschtli is a box in the kitchen
> Hi Chuchichäschtli,
> you can use ogc_fid as primary key from your tables or create on schema for
> one village.
> What "Chuchichäschtli" mean in german?
> Gr
> Ralf
> Am Montag 20 September 2010 09:34:11 schrieb Thomas Andres:
> > Dear List,
> > im Swiss and my English isnt the most best. Even, I will try the
> > explain
> > You my problem. Perhaps You will understand J
> > In Switzerland the parts of the country were measured by different
> offices.
> > The informations of the terrain (parcelles, rows, lakes, jungle etc
> ) are
> > exchanged by Interlis Files (*.itf).
> > With ogr2ogr this files can be imported into a Postgres Database.
> > When You import only one file, its not a problem. Every Line, Point,
> > Polygone and so on, has its own Feature-Id, which can be linked with
> > another feature.
> > I.e.: The geometry of a parcelle is linked with his number.
> > Now, when I would like add a second village to my GIS, in the same
> > Database, to be loaded in Mapserver with a mapfile layer
> the parcelle
> > with the same Feature ID will appear twice
> so the link to the number of
> > the parcelle is wrong
> > What I made in a first time: after have imported the first village, I add
> > to the primary and foreign keys, which I really Im going to use in my
> GIS
> > a Char (a in example)
> by using PostgreSQL
> only after I imported the
> > second file. This is a solution which works, but not for long time J
> > I asked me, or better: I ask You, if there isnt a mechanism in PostGIS
> > or
> > PostgreSQL which is specially implemented for this kind of collage
> Some
> > kind of namespaces or
> I dont know
> You understand =-) ?
> > Thänk You very much for Your help.
