[postgis-users] Using both && and ST_Intersects in a query
Andrea Peri 2007 aperi2007 at gmail.com
Thu Sep 23 09:52:35 PDT 2010
>This would be true if ST_Intersects would'nt already include a bounding box
>intersection step before trying the real intersection algorithm.
>The magic is already in PostGIS :)
ok, I'm very glad to know this.
Now I need just another little step to complete the question:
The bounding-box intersection used in the ST_Intersects is used even
when there isn't an index available on geometry field ?
Thx for clarification.
Andrea.
Il 23/09/2010 18:36, Vincent Picavet ha scritto:
> Hi,
>> this mean that a query filter like this:
>> select ...
>> from
>>     table1 as a,
>>     table2 as b
>> where
>> (  (a.geom&&  b.geom)&&  (ST_Intersects(a.geom,b.geom)=true ) )
>> if faster than a query without the&&
>> like this:
>> select ...
>> from
>>     table1 as a,
>>     table2 as b
>> where
>> (  ST_Intersects(a.geom,b.geom)=true  )
> But you can try the difference with _st_intersects, which only does the
> geometric intersection without the bbox comparison first.
> Vincent
