[postgis-users] query gist bbox
Ralf Suhr
Ralf.Suhr at itc-halle.de
Fri Sep 24 01:35:38 PDT 2010
Hi Till,
you can use casting to get the bbox.
geom_column::box2d::geometry
Gr
Ralf
Am Freitag 24 September 2010 10:02:43 schrieb Till Kirchner:
> Hello together,
> I would like to visualize and query the bboxes used by a gist (rtree)
> index.
> I thought there should be an easy and fast way to get the maximum extend
> of geometries stored in a column by simply
> querying the corners of the bbox which covers all data used by the index.
> Is there a function which allows to get information about bboxes used by
> a gist index?
> Thanks in advance
> Till
