[postgis-users] geos proj stats modules all=v.1
Nicklas Avén
nicklas.aven at jordogskog.no
Tue Sep 28 07:39:23 PDT 2010
great that it is working now :-)
/Nicklas
2010-09-28 Rebecca Cooper wrote:
Just to let you know, third time's a charm... I reinstalled PostgreSQL and PostGIS and it didn't error when re-installing this time. I can now buffer my geometries. phew
>Thank you for the quick response Nicklas, it's very reassuring to know that people are ready to help so quickly.
>Rebecca
>Date: Tue, 28 Sep 2010 15:30:44 +0200
>From: nicklas.aven at jordogskog.no
>To: postgis-users at postgis.refractions.net
>CC:
>Subject: Re: [postgis-users] geos proj stats modules all=v.1
>Message bodyHallo> > >I get the same answer for postgis_version()>I just tells that postgis is compiled with geos and proj> >try postgis_full_version instead, what do you get then?> >/Nicklas
>Hi,
>>I have recently tried installing postgesql 8.4 with PostGIS 1.5 ( now clean installs with v 1.4 instead ) onto to separate machines using the windows installer. I have only now realised that the buffer function is not available, despite being in the functions list. I checked the postgis_version() and the result was "1.4 USE_GEOS=1 USE_PROJ=1 USE_STATS=1".
>>The last time I installed this at work the correct geos module etc were installed. I have looked around and I can't find anything to say how I can manually change this. I believe it should be looking at the corrrect library as I found in the bin folder the libgeos-3-2-0.dll, libgeos_c-1.dll, libproj.dll files, but I don't know anything about them or how they are being referenced, other thatn one says 3.2 on it. I have tried looking for a postgis_config file, but I don't think that is something available to windows users(?)
>>Sorry for being so clueless, but I am worried as I have a deadline on friday and need to be able to use this functionality!
>>many thanks,
>>Rebecca
>_______________________________________________postgis-users mailing listpostgis-users at postgis.refractions.nethttp://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100928/b8d18a51/attachment.html>
