[postgis-users] geos proj stats modules all=v.1
Rebecca Cooper rmcooper at live.com
Tue Sep 28 07:04:37 PDT 2010
Just to let you know, third time's a charm... I reinstalled PostgreSQL and PostGIS and it didn't error when re-installing this time. I can now buffer my geometries. phew
Thank you for the quick response Nicklas, it's very reassuring to know that people are ready to help so quickly.
Rebecca
Date: Tue, 28 Sep 2010 15:30:44 +0200
To: postgis-users at postgis.refractions.net
CC:
Subject: Re: [postgis-users] geos proj stats modules all=v.1
	Message body
Hallo
I get the same answer for postgis_version()
I just tells that postgis is compiled with geos and proj
try postgis_full_version instead, what do you get then?
/Nicklas
		2010-09-28 Rebecca Cooper wrote:
		>I have recently tried installing postgesql 8.4 with PostGIS 1.5 ( now clean installs with v 1.4 instead ) onto to separate machines using the windows installer.  I have only now realised that the buffer function is not available, despite being in the functions list.  I checked the postgis_version() and the result was "1.4 USE_GEOS=1 USE_PROJ=1 USE_STATS=1".
		>The last time I installed this at work the correct geos module etc were installed.  I have looked around and I can't find anything to say how I can manually change this.  I believe it should be looking at the corrrect library as I found in the bin folder the  libgeos-3-2-0.dll, libgeos_c-1.dll, libproj.dll files, but I don't know anything about them or how they are being referenced, other thatn one says 3.2 on it.  I have tried looking for a postgis_config file, but I don't think that is something available to windows users(?)
		>Sorry for being so clueless, but I am worried as I have a deadline on friday and need to be able to use this functionality!
		>many thanks,
		>Rebecca
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100928/e199e8ca/attachment.html>
