[postgis-users] shp2pgsql import error: invalid byte sequence for encoding "UTF8": 0x96
Burgholzer, Robert (DEQ)
Robert.Burgholzer at deq.virginia.gov
Fri Apr 1 13:30:33 PDT 2011
I am importing a file from some colleagues that is throwing an error
that I have never encountered before (nor it seems, has Google). What
is interesting is that this file was an update sent to me whose only
supposed difference is that it is a POINT shapefile instead of a
MULTIPOLYGON. The MULTIPOLYGON version worked fine, of course I have
no way of knowing what else has REALLY changed with this dataset. Any
help would be appreciated. The error occurs with only a subset of the
records, and occurs upon cat'ing the file to psql like so:
cat sql/observed_vdgif_xy.sql | psql aquatic_bio -U robertwb
ERROR: byte sequence for encoding "UTF8": 0x96
HINT: This error can also happen if the byte sequence does not match
the encoding expected by the server, which is controlled by
"client_encoding".
Regards,
r.b.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110401/20e39810/attachment.html>
