[postgis-users] shp2pgsql import error: invalid byte sequence forencoding "UTF8": 0x96
Burgholzer, Robert (DEQ) Robert.Burgholzer at deq.virginia.gov
Fri Apr 1 14:08:18 PDT 2011
Ahhh, it was my "0x96" that defeated le Google.  The fix, for those of
you awaiting the outcome with bated  breath:
Shp2psql -W latin1 ...
Encoding is all good from there on out.  Thanks to Leo who posted a
solution in April of 2009!!!
r.b.
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Sent: Friday, April 01, 2011 4:31 PM
To: postgis-users at refractions.net
Subject: [postgis-users] shp2pgsql import error: invalid byte sequence
I am importing a file from some colleagues that is throwing an error
that I have never encountered before (nor it seems, has Google).    What
is interesting is that this file was an update sent to me whose only
supposed difference is that it is a POINT shapefile instead of a
MULTIPOLYGON.   The MULTIPOLYGON version worked fine, of course I have
no way of knowing what else has REALLY changed with this dataset.  Any
help would be appreciated.  The error occurs with only a subset of the
records, and occurs upon cat'ing the file to psql like so:
cat sql/observed_vdgif_xy.sql | psql aquatic_bio -U robertwb
ERROR: byte sequence for encoding "UTF8": 0x96
HINT:  This error can also happen if the byte sequence does not match
the encoding expected by the server, which is controlled by
"client_encoding".
Regards,
r.b.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110401/4d8c8b5c/attachment.html>
