[postgis-users] shp2pgsql - bad date formats
Jeff Dege
jeff.dege at korterra.com
Thu Apr 14 10:56:33 PDT 2011
I'm trying to load a shapefile into a PostGIS database, using shp2pgsql and psql.
It's failing because a couple of the sql insert statements have date fields containing '0'.
ERROR: date/time field value out of range: "0"
HINT: Perhaps you need a different "datestyle" setting.
What I need is for these features to be inserted with NULL date fields, instead of '0'.
Currently, I'm running psql on the generated .sql file, capturing the output. I then search the output to identify the problem statement, delete it from the generated file, and then run psql on it again, until there are no errors. I save the lines I deleted in another file, and then hand-edit them, and insert them separately.
This is tiresome, tedious, and slow.
Anyone have any better ideas?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110414/8e73a018/attachment.html>
