[postgis-users] shp2pgsql - bad date formats
Sandro Santilli
strk at keybit.net
Thu Apr 14 12:00:06 PDT 2011
On Thu, Apr 14, 2011 at 12:56:33PM -0500, Jeff Dege wrote:
> ERROR: date/time field value out of range: "0"
> HINT: Perhaps you need a different "datestyle" setting.
> What I need is for these features to be inserted with NULL date fields, instead of '0'.
You may try to:
1) prepare the table using -p
2) alter the table to use varchar for the date field
3) fill the table using -a
4) fix the dates within the db
Or, which could be a good investiment of your time, look
at "datestyle" setting as hinted... there might be a style
in which '0' is accepted.
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
