[postgis-users] st_find_extent
Sandro Santilli strk at keybit.net
Wed Apr 20 05:52:11 PDT 2011
On Wed, Apr 20, 2011 at 02:47:24PM +0200, Tonton wrote:
> hello
> i have this new error after add a new table in my postgis database
> i try this : SELECT st_find_extent('Courly4326','geometry')
> but it is warn and if i try in pgadmin III i can read this
> ERREUR:  la relation « Courly4326 » n'existe pas
> LIGNE 1 : SELECT extent("geometry") FROM "Courly4326"
> REQUÊTE : SELECT extent("geometry") FROM "Courly4326"
> CONTEXTE : PL/pgSQL function "st_find_extent" line 7 at FOR sur une
> instruction EXECUTE
> does it mean my table Courly4326 not seeing by postgresql ?
> i try with an other table where it was working before and it is broken now
> with same error
> and i don't understand why
Which schema contain 'Coulry4326' ? Is that schema in your path ?
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
