[postgis-users] GeomFromText in a user function.
Charles E. Deaton
CDeaton at corp.realcomp.com
Tue Apr 26 10:46:01 PDT 2011
I'm going to apologize up front for being a nood.
I have been trying to create a user function that I can call as needed
by passing in bbox coordinates. I have the standard SQL working as show
below;
SELECT *
FROM "MyTable" t
WHERE WITHIN(
GeomFromText('POLYGON((5 1, 8 4, 7 3, 6 2, 5 1))'),t.geom);
The above runs fine, they are not valid values based on the geom column
is based on lat/lon.
When I place it in a PostgreSQL function it keeps telling me "type
"geomfromtext" does not exist".
I have run out of ideas and can't find a lot on the net about PostgreSQL
function similar to this. Below is my last attempt:
CREATE OR REPLACE FUNCTION fn_Poly(double precision, double precision,
double precision, double precision, double precision, double precision,
double precision, double precision)
RETURNS SETOF " MyTable" AS
'SELECT *
FROM " MyTable" t
WHERE WITHIN(
GeomFromText('' || '''''''' || ''''POLYGON(('' ||
$5 || '' '' || $1 || '', '' ||
$8 || '' '' || $4 || '', '' ||
$7 || '' '' || $3 || '', '' ||
$6 || '' '' || $2 || '', '' ||
''))'')'''' || '''',t.geom)'
LANGUAGE sql;
Any help would be greatly appreciated.
Charlie
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110426/8a7c3a31/attachment.html>
