[postgis-users] GeomFromText in a user function.
Paragon Corporation lr at pcorp.us
Tue Apr 26 12:37:50 PDT 2011
Charles,
Which version of PostGIS are you using?
If you are using trunk (PostGIS 2.0), those won't work since they were
removed.  Use ST_GeomFromText and ST_Within instead.  Though I don't think
that is the problem based on your error.
It's  hard to read you code.  Please use $$ $$ quoting instead of ' that way
you don't have to escape out your inner quotes.
Leo
http://www.postgis.us
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Charles
E. Deaton
Sent: Tuesday, April 26, 2011 1:46 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] GeomFromText in a user function.
I'm going to apologize up front for being a nood.
I have been trying to create a user function that I can call as needed by
passing in bbox coordinates. I have the standard SQL working as show below;
SELECT *
FROM "MyTable" t
WHERE WITHIN(
GeomFromText('POLYGON((5 1, 8 4, 7 3, 6 2, 5 1))'),t.geom);
The above runs fine, they are not valid values based on the geom column is
based on lat/lon.
When I place it in a PostgreSQL function it keeps telling me "type
"geomfromtext" does not exist".
I have run out of ideas and can't find a lot on the net about PostgreSQL
function similar to this. Below is my last attempt:
CREATE OR REPLACE FUNCTION fn_Poly(double precision, double precision,
double precision, double precision, double precision, double precision,
double precision, double precision)
RETURNS SETOF " MyTable" AS
'SELECT *
FROM " MyTable" t
WHERE WITHIN(
GeomFromText('' || '''''''' || ''''POLYGON(('' ||
                $5 || '' '' || $1 || '', '' ||
                $8 || '' '' || $4 || '', '' ||
                $7 || '' '' || $3 || '', '' ||
                $6 || '' '' || $2 || '', '' ||
                ''))'')'''' || '''',t.geom)'
LANGUAGE sql;
Any help would be greatly appreciated.
Charlie
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110426/6ca71f43/attachment.html>
