[postgis-users] Calculating variance of a set of points
Birgit Laggner
birgit.laggner at vti.bund.de
Wed Apr 27 05:46:57 PDT 2011
Hi Aren, hi Brent,
I would only add to Brent's suggestion, that you could use st_centroid
of the collected multipoint instead of calculating average x and y
points for each reference mark - perhaps like this:
select l.ref_mark_id,
avg(ST_Distance(l.location,a.avg_location))
from loc_table l
inner join
(select ref_mark_id,
st_centroid(st_collect(location)) as avg_location
from loc_table
group by ref_mark_id) a
on l.ref_mark_id=a.ref_mark_id
group by l.ref_mark_id;
Regards,
Birgit.
Am 25.04.2011 03:22, schrieb pcreso at pcreso.com:
> Hi Aren,
> If I understand the question, then off the top of my head, untested &
> without getting into calculating spheroidal distances instead of
> cartesian ones :-) ...
> given a table loc_table with columns:
> ref_mark_id
> location (point geometry)
> something like:
> select ref_mark_id,
> from loc_table l,
> setsrid(makepoint(avg(x(location)),
> avg(y(location))),4326) as avg_location
> group by ref_mark_id as foo) a
> where l.ref_mark_id - a.ref_mark_id
> group by ref_mark_id;
> Should work. ie: generate a virtual table as a query which provides
> the average X/Y point for each marker, then join this to the original
> table by marker to average the distances between each point & the
> average point, grouped by marker.
> HTH
> Brent Wood
> --- On *Mon, 4/25/11, Aren Cambre /<aren at arencambre.com>/* wrote:
> From: Aren Cambre <aren at arencambre.com>
> Subject: [postgis-users] Calculating variance of a set of points
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Date: Monday, April 25, 2011, 12:42 PM
> I have a table with events. Each event happened at a listed
> reference marker on a highway, and it also has latitude and
> longitude as recorded by an observer of the event.
> There are many events at each reference marker.
> I want to check the precision of the latitude and longitude for
> events recorded at each reference marker. Roughly, I would collect
> all latitude/longitude points at each reference marker, then I
> would want to see the average distance between each point and a
> centroid of all the points.
> How would I do that with PostGIS?
> I understand how to convert latitude/longitude to a geometry type,
> but I am not clear how to do the rest without iterating through
> each point individually.
> Aren
> -----Inline Attachment Follows-----
> postgis-users mailing list
> </mc/compose?to=postgis-users at postgis.refractions.net>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110427/57f981cb/attachment.html>
