[postgis-users] ERROR: could not find function "isvalidreason" in file "/usr/local/postgresql-8.2.20/lib/postgis-1.4.so"
Sandro Santilli strk at keybit.net
Tue Aug 9 01:40:10 PDT 2011
On Tue, Aug 09, 2011 at 10:04:41AM +0200, ml ml wrote:
> I am using postgres 8.2.20, postgis 1.4.2 and geos.3.3.0 from source.
> pg_restore: [archiver (db)] Error from TOC entry 43383; 1255 3510237
> FUNCTION st_isvalidreason(geometry) pgsql
> pg_restore: [archiver (db)] could not execute query: ERROR:  could not
Did you run "make install" ?
Check ctime on /usr/local/postgresql-8.2.20/lib/postgis-1.4.so
Or run:
  nm /usr/local/postgresql-8.2.20/lib/postgis-1.4.so | grep -i validreason
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
