[postgis-users] ERROR: could not find function "isvalidreason" in file "/usr/local/postgresql-8.2.20/lib/postgis-1.4.so"
ml ml
mliebherr99 at googlemail.com
Tue Aug 9 01:04:41 PDT 2011
Hello,
i am trying to restore a postgres dump on a freshly installed Debian
Squeeze Box.
I am using postgres 8.2.20, postgis 1.4.2 and geos.3.3.0 from source.
Postgresql 8.2.20: ./configure --prefix=/usr/local/postgresql-8.2.20
--with-perl --with-openssl --with-libxslt --with-libxml
Geos: ./configure --prefix=/usr/local/geos-3.3.0
Postgis: ./configure
--with-pgconfig=/usr/local/postgresql-8.2/bin/pg_config
--with-geosconfig=/usr/local/geos-3.3/bin/geos-config
Restore:
/usr/local/postgresql-8.2/bin/pg_restore -U pgsql -d test
--exit-on-error --no-owner /root/test_dev-Sat-18.bin pg_restore:
[archiver (db)] Error while PROCESSING TOC:
pg_restore: [archiver (db)] Error from TOC entry 43383; 1255 3510237
FUNCTION st_isvalidreason(geometry) pgsql
pg_restore: [archiver (db)] could not execute query: ERROR: could not
Command was: CREATE FUNCTION st_isvalidreason(geometry) RETURNS text
AS '$libdir/postgis-1.4', 'isvalidreason'
LANGUAGE c IMMUTAB...
I read that st_isvalidreason needs goes >= 3.1 which i actually use.
I used to use geos 3.0 from the debian squeeze repo, which i replaced
(see source config above)
Kind Regards,
Mario
