[postgis-users] using pgShapeLoader to upload csv file
Charles Galpin
cgalpin at lhsw.com
Mon Aug 8 05:55:40 PDT 2011
Assuming you can export them in a tab delimited or CSV format, you can use the "copy" command to import the data into postgresql.
http://www.postgresql.org/docs/9.0/static/sql-copy.html
hth
charles
On Aug 8, 2011, at 6:11 AM, Robert Buckley wrote:
> Hi,
> What is the easiest way to load a table into posgresql?
> Usually I would just upload a shapefile into the database, but for a specific project I am required to build a relational database system with 1 shapefile and lots of other tables linked with Foreign Keys.
> I have never done this before for a Postgis project and was wondering on the best way to do this.
> The tables and shapes have been already created in an ESRI personal geodatabase.
> thanks for any help,
> Rob
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110808/1f57aa89/attachment.html>
