[postgis-users] spatial indices on two geometry or rast columns
Vishal Mehta
vishal.mehta at sei-us.org
Thu Aug 11 12:16:22 PDT 2011
Hi all,
I have some vector layers in a postgis database in EPSG 4326. Spatial indices have been built using GIST on the same (EPSG 4326) geometries on a geometry column called geom.
I'd like to transform these layers to UTM (EPSG 32643). I was thinking of creating a new geometry column for each table and
ALTER TABLE wards ADD column geom_utm geometry;
UPDATE wards SET geom_utm = ST_TRANSFORM(geom,32643);
Should I, (and can I) create another gist index on the transformed geometry?
The same qn applies on a raster table I have called srtm_table - should I and can I add
- a new 'rast' column called rast_utm with transformed SRID in similar fashion above, and then add a gist index on the rast_utm column?
CREATE INDEX "srtm_table_rast_gist_idx" ON "public"."srtm_table" USING GIST (st_convexhull(rast_utm));
Thanks,
Vishal
Vishal K. Mehta<http://sei-us.org/about/staff_person/19>, Ph.D.
Staff Scientist,
Stockholm Environment Institute-US
400 F St, Davis, CA 95616
http://sei-us.org/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110811/a933991f/attachment.html>
