[postgis-users] ERROR: Unknown geometry type: 0 - Unknown
Andreas Forø Tollefsen andreasft at gmail.com
Wed Aug 17 06:14:23 PDT 2011
Hi all.
I was experimenting with some raster functionality in the SVN 6874. However,
as there were some fixed bugs in later version I decided to create a new
database on my server using SVN 7749.
When installing this i must have updated some of the libraries, GEOS i guess
and maybe others.
The problem now is that while the 7749 database works flawless, the 6874
have become corrupted.
When querying any geometry column i get this:
SELECT cshapes.geom FROM cshapes;
results in:
It does not matter whether i query from remote or from the actual server.
Any ideas on whether it is possible to solve this issue?
I will eventually recreate all of my data on the 7749 database, but as for
now i need to access the geometries stored in the 6874 database.
Thank you in advance.
Andreas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110817/2e12ad1a/attachment.html>
