[postgis-users] Cursor names in a self-nested function
Kidd, David M
d.kidd at imperial.ac.uk
Thu Aug 18 06:22:32 PDT 2011
Appologies, I posted this to the wrong list.
David M. Kidd
Research Associate
Center for Population Biology
Silwood Park Campus
Imperial College London
0207 594 2470
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Kidd, David M
Sent: 18 August 2011 13:44
To: PostGIS Users Discussion
Subject: [postgis-users] Cursor names in a self-nested function
I am trying to write a function that contains a cursor and iteratively calls itself.
It is along the lines of,
CREATE FUNCTON test(id integer) RETURNS TEXT AS
$BODY$
DECLARE
mycursor CURSOR FOR SELECT * FROM myfunction(id);
newid INTEGER;
out = TEXT;
BEGIN
out := '';
OPEN mycursor;
LOOP
FETCH my_cursor INTO newid;
out := out || test (newid);
END LOOP;
RETURN out;
END;
$BODY$
LANGUAGE 'plpgsql' VOLATILE
This returns an ERROR stating that "mycursor" is already in use.
I understand this occurs because cursor names must be unique across, as well as within, functions.
So, my question is whether there is a way I can dynamically declare a cursor name, for example by appending a incremental number or guid to make the name unique?
Just trying to concatenate two passed arguments in the DECLARE statement unsurprisingly fails.
Any other solutions are of cause welcome.
Many thanks,
- David
David M. Kidd
Research Associate
Silwood Park Campus
0207 594 2470
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110818/ff1acf1f/attachment.html>
