[postgis-users] closest point
Jaime Casanova
jaime at 2ndquadrant.com
Thu Aug 18 11:41:18 PDT 2011
I'm trying to get the closest point to a given one, complete SQL is as follows:
select DISTINCT fl.stime, ll.latitude, ll.longitude,
(select (case when data_origin = 'SNT' then lic_name else lic_tx_name end) as lic_tx_name
from transmitter_mv
where tx_freq::decimal = fl.frequency::decimal
-- and st_dwithin(punto, st_makepoint(ll.longitude, ll.latitude), 50, false)
-- order by st_distance(punto, st_makepoint(ll.longitude, ll.latitude))
and st_distance_sphere(transmitter_mv.punto, ll.punto) < 50
order by st_distance_sphere(transmitter_mv.punto, ll.punto)
limit 1
) as estacion,
fl.level, fl.frequency / 1000000 as frecuencia
from rowfreqlevel fl
join rowlatlong ll ON ll.row_id = fl.row_id
WHERE stime >= '2011-05-24 23:39' AND stime <= '2011-05-24 23:41'
as you see, for every set of long/lat i need to find the closest
transmitter. i tried it creating a point in the query and also adding a
point column in the table (in both cases i created gist indexes, the
first time over the st_makepoint() function then over the geometry
column) nevertheless i always get a seq scan. any idea how to improve
this query? just in case here is the plan: http://explain.depesz.com/s/UY3
Jaime Casanova www.2ndQuadrant.com
Professional PostgreSQL
Soporte 24x7, desarrollo, capacitación y servicios
