[postgis-users] ERROR: geometry contains non-closed rings
Sandro Santilli
strk at keybit.net
Fri Aug 19 04:05:18 PDT 2011
A newer PostGIS should give you a valid return from ST_IsValidReason
rather than an exception for those non-closed linear rings.
And the ST_MakeValid function should close them for you.
I'm afraid "newer" means 2.0.0SVN here, which also means dump-reload
(I hope you do can dump, can you ?)
For a "simpler" solution you'll need to write a function to ensure
rings are closed.
--strk;
On Fri, Aug 19, 2011 at 03:36:27PM +0530, Mr. Puneet Kishor wrote:
> On Aug 19, 2011, at 10:26 AM, Mr. Puneet Kishor wrote:
> > Ben,
> > On Aug 18, 2011, at 10:04 PM, Ben Madin wrote:
> >> SELECT gid, st_isvalidreason(the_geom), st_summary(the_geom) FROM data WHERE st_isclosed(the_geom) is FALSE;
> > I am not entirely sure what the above was supposed to accomplish (I am assuming it would have given me the reason for features being invalid), however, I ran the query and I got 0 (zero) rows.
> hmmmm.... a bit more on the above
> SELECT Count(*) FROM data WHERE ST_IsClosed(the_geom) IS FALSE;
> 0 rows
> SELECT Count(*) FROM data WHERE ST_IsValid(the_geom) IS FALSE;
> NOTICE: IllegalArgumentException: Points of LinearRing do not form a closed linestring
> NOTICE: Ring Self-intersection at or near point -125.35 63.3748
> NOTICE: Ring Self-intersection at or near point -105.317 25.7493
> NOTICE: Ring Self-intersection at or near point -79.7995 15.6005
> NOTICE: Ring Self-intersection at or near point -108.085 29.1395
> NOTICE: Ring Self-intersection at or near point -110.182 25.8712
> NOTICE: Self-intersection at or near point -119.188 77.3311
> NOTICE: Ring Self-intersection at or near point -120.647 48.8028
> NOTICE: Ring Self-intersection at or near point -124.845 61.0461
> NOTICE: Ring Self-intersection at or near point -100.63 62.7163
> NOTICE: Self-intersection at or near point -69.7338 64.1648
> NOTICE: Self-intersection at or near point -69.2501 58.2279
> NOTICE: Self-intersection at or near point -65.9125 52.0649
> NOTICE: Ring Self-intersection at or near point -74.8998 50.7265
> NOTICE: Self-intersection at or near point -82.6883 72.1031
> NOTICE: Ring Self-intersection at or near point -27.1663 71.0088
> NOTICE: Ring Self-intersection at or near point -99.0254 23.1045
> NOTICE: Ring Self-intersection at or near point -93.6802 37.1155
> NOTICE: Ring Self-intersection at or near point -73.2305 9.59044
> NOTICE: Ring Self-intersection at or near point -63.4384 13.1596
> 21 rows
> SELECT gid, ST_IsValidReason(the_geom) FROM data WHERE ST_isvalid(the_geom) IS FALSE;
> ERROR: POSTGIS2GEOS conversion failed
> ********** Error **********
> SQL state: XX000
> postgis-users mailing list
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
