[postgis-users] simple puffer script
Charles Galpin cgalpin at lhsw.com
Tue Aug 23 10:49:51 PDT 2011
Rob you can do this with geoserver and it's "sql view" feature.  The docs cover it pretty well.
hth
charles
On Aug 23, 2011, at 12:26 PM, Robert Buckley wrote:
> Hi,
> I have to use postgis to create a puffer layer. I could do this within postgis, but the problem is that I have to display the result in my webapp!
> I have seen many examples on how to puffer, but none where a user inputs a value from a textbox e.g 50 and presses a button to calculate a puffer over the data with a 50m puffer and then displays the resulting vector layer in the openlayers map.
> Is this very complex?
> How should I start coding this?  PHP to script the postgis query?
> thanks for any scripts, tips or advice.
> yours,
> Rob
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110823/8fb7d83d/attachment.html>
