[postgis-users] How to extract multiple convex hulls from a query?
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Aug 24 13:41:04 PDT 2011
Thanks, This is what I ended up with:
select b.slice, st_convexhull(st_collect(a.the_geom)) as hull from
(SELECT * FROM function_returning_points() ) as a,
(select generate_series(500, 1500, 500) as slice) as b
where a.dist <= b.slice group by b.slice order by b.slice;
This is somewhat simplified from the actual query but I think it is
doing what I want.
-Steve
On 8/24/2011 3:51 PM, Robert Hollingsworth wrote:
> Steve,
> I think I've done something similar with ST_ConvexHull( ), where I had a
> data set full of LINESTRING geometries and wanted to ConvexHull them
> into as many separate polygons as there are unique sets of values for
> two or three attributes stored on the objects. paraphrased below to
> obscure original detail:
> SELECT
> ST_ConvexHull ( ST_Collect ( the_geom ) ) AS poly,
> table1.attr1,
> table1.attr2,
> table1.attr3
> FROM
> table1,
> table2
> WHERE
> some condition AND
> some other condition AND
> GROUP BY
> table1.attr1,
> table1.attr2,
> table1.attr3;
> I think in your case if you could do something like this or similar?
> select
> func_returning_dist_as_one_of_5_ranges(the_distance) AS range,
> from table
> where....
> GROUP BY range;
> Hi all,
> I am trying to construct multiple convex hulls from a series of point
> where I have an attribute dist for each point.
> What I want is to generate convex hulls for expanding rings where dist
> <= slice up to some max_dist.
> So if slice=100 and max_dist=500, then each hull would be:
> 1. all points <= 100
> 2. all points <= 200
> 3. all points <= 300
> 4. all points <= 400
> 5. all points <= 500
> So I have a procedure that generates the points and is fairly costly to
> run. I would like to run it once and extract all the hulls in a single
> pass if possible.
> I'm currently running postgresql 8.3 and "POSTGIS="1.5.1"
> GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.6.1, 21 August 2008"
> LIBXML="2.6.32" USE_STATS"
> Any thoughts or snippets would be appreciated.
> Thanks,
> -Steve
> postgis-users mailing list
