[postgis-users] PostGIS Raster efficient enough to get height given coords from a large DEM?
Bborie Park
bkpark at ucdavis.edu
Sun Dec 4 10:51:06 PST 2011
On Sun, Dec 4, 2011 at 6:55 AM, Stefan Keller <sfkeller at gmail.com> wrote:
> 2011/12/4 Bborie Park <bkpark at ucdavis.edu> wrote...
>>> Q2: Given the raster has a resolution (grid) of - say at best - 30m,
>>> does this function really interpolate, given the input is an arbitrary
>>> coordinate (I can't find a hint to that in the docs
>>> (http://postgis.refractions.net/documentation/manual-svn/RT_ST_Value.html))?
>> There is no interpolation. It literally is a pin stuck through the raster.
> You mean aka 'snap-to-grid', i.e. returning the closest grid point?
> Which grid point exactly?
Correct. It converts your geospatial value into a grid pixel x, y
(row, column) and then gets the value at the x, y.
> I now found a related thread here where elliott-22 asks "what if the
> yourLongitude, yourLatitude values provided in the query are not grid
> points in that they fall within a bounding pixel grid. Only values
> for the intersection points are known so how does a non-intersecting
> point get assigned a value from the query?" (see
> http://old.nabble.com/Retrieving-Data-from-PostGIS-Raster-using-ST_Value-td32638248.html
> at bottom of thread, Oct 17, 2011; 09:27pm)
> There Pierre answers:
>> Point outside the area covered by the grid are assigned NULL. There is not inter- or extra- polation done.
> But the question is about a query point (of float type) lying inside
> the perimeter but outside the grid nodes (probably integer based!
> These query points are inside the convex hull of the whole raster but
> they still don't "fall" on a regular grid point (see the figure of
> eliott-22 above).
You can't think that the value is only significant for the upper-left
corner of a pixel (regular grid point) as each pixel represents an
area (hence the geotransform values of scale, upperleft corner and
skew). Since each pixel of a raster represents an area bounded by the
pixel's four corners with a singular value for that area (per band),
any point that falls within that pixel would have the same singular
value.
> What is exactly happening here in ST_Value()?
My response above. ST_Value has the exact same behavior you'd expect
if you used the "Identify" tool in ArcGIS, ENVI, ERDAS, qgis and
clicked anywhere on a pixel. It gets the value(s) (if more than one
band) of the pixel your cursor is over.
> Pierre also answered in the thread mentioned above my interpolation question:
>> Interpolating the elevation of a point is another story.
>> You could build a grid of 8, 15 or 24 points around your lat/long,
>> query the elevation at those points and use your algorithm to compute the interpolation.
> How do I really control which grid points are chosen - given an
> arbitrary (floating number) coordinate?
For what you need, you may want to convert an area of the raster
around your coordinates to geometries.
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
