[postgis-users] High Concurrency R* in GiST?
Jan Hartmann
j.l.h.hartmann at uva.nl
Tue Dec 6 01:44:14 PST 2011
"Worse is better" :-) See:
http://www.jwz.org/doc/worse-is-better.html
Cheers,
Jan
On 12/05/2011 10:09 PM, Paul Ramsey wrote:
> On Mon, Dec 5, 2011 at 11:05 AM, C. Mundi<cmundi at gmail.com> wrote:
>> I get the impression that GiST hides a lot of
>> implementation details. So I am hungry for details which will help me
>> assess postGIS/postgreSQL for my application.
> This is the key point, and it is so: the physical implementation
> details are hidden behind the GiST API. As a result the R-Tree
> implementation is a "standard" one, not an R* (though the split method
> in Ang/Tan not Guttman). And as a result you can't do things like
> rebalance the tree as specified in the R* recipe. The GiST API really
> is quite narrow. You have the consistent function to control reads and
> the compress/picksplit controlling writes.
> So if you're looking for optimal tree construction you've come to the
> wrong place. The primary benefit of the PostGIS indexing system is not
> it's optimal nature but its existence: it's already here, you can
> insert and query data with simple SQL, it does do locking and
> consistent operations thanks to the postgresql infrastructure wrapped
> around it.
> As an architect my recommendation would be: since the development
> overhead in building your system from scratch will be quite high,
> investing the time into a load test on PostGIS first could save you a
> lot of time if it turns out that even our imperfect system is actually
> good enough to meet your needs.
> Best,
> P.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111206/1f414497/attachment.html>
