[postgis-users] ERROR: pt_in_ring_2d: V[n] != V[0]
Paul Ramsey pramsey at opengeo.org
Thu Dec 8 10:25:16 PST 2011
First confirm if PostGIS 1.5.3 is any better.
If it's not, this should not be a major problem to fix.
P.
On Thu, Dec 8, 2011 at 10:15 AM, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> This was loaded via:
> ogr2ogr -t_srs EPSG:4326 out.shp in.shp
> This complained about something but seems to have passed on at least some of
> the problems.
> shp2pgsql ...
> No complaints there - so maybe this command should be extended to validate
> geometry and have a rule for how to handle bad ones like NULL the geom or
> try to fix it, etc.
> I was able to locate the first issue, and after about 30 mins of trying this
> and that was able to locate the bad record and dump with astext and manually
> copy the start point  to an new end point and fix that.
> The problem is I have 503 more records that are not valid and want to fix
> them but the tools do not allow me to easily sort out the simple invalid
> from the more severe ones because these commands are dying on fatal errors
> instead of recognizing it is a fatal condition are reporting it
> appropriately. :(
> So my first need it to sort the simple and problematic cases. Any ideas on
> this?
> Thanks,
>  -Steve
> On 12/8/2011 12:17 PM, Paul Ramsey wrote:
>> Somehow you've snuck an unclosed polygon into the system. They don't
>> usually get in, because the parser disallows them.
>> This will make dumping a test data tricky at best...
>> P.
>> On Thu, Dec 8, 2011 at 8:42 AM, Stephen Woodbridge
>>> Hi all,
>>> I'm getting this error:
>>> select gid from parcels where not isvalid(the_geom);
>>> ERROR:  pt_in_ring_2d: V[n] != V[0] (-83.5001 38.244 != -83.5001 38.244)
>>> ********** Error **********
>>> SQL state: XX000
>>> select gid, st_isvalidreason(the_geom) from parcels where not
>>> isvalid(the_geom);
>>> NOTICE:  IllegalArgumentException: Invalid number of points in LinearRing
>>> found 3 - must be 0 or>= 4
>>> ERROR:  POSTGIS2GEOS conversion failed
>>> SQL state: XX000
>>> "POSTGIS="1.5.1" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.6.1, 21 August
>>> 2008"
>>> LIBXML="2.6.32" USE_STATS"
>>> This just seems very bad in that isvalid() and st_isvalidreason() should
>>> never fail, IMO.
>>> -Steve
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
