[postgis-users] ERROR: pt_in_ring_2d: V[n] != V[0]
Stephen Woodbridge woodbri at swoodbridge.com
Thu Dec 8 12:48:13 PST 2011
Upgraded to PostGIS 1.5.3 and get the same problem.
select gid, st_isvalidreason(the_geom) from parcels where not
isvalid(the_geom);
...<lots of non-fatal notice massages>
NOTICE:  Ring Self-intersection at or near point -84.5006 38.044
NOTICE:  Ring Self-intersection at or near point -84.5064 37.988
NOTICE:  Ring Self-intersection at or near point -84.5097 38.0421
NOTICE:  Self-intersection at or near point -84.4921 38.0534
NOTICE:  Ring Self-intersection at or near point -84.5265 38.0425
NOTICE:  IllegalArgumentException: Invalid number of points in
LinearRing found 3 - must be 0 or >= 4
ERROR:  POSTGIS2GEOS conversion failed
********** Error **********
SQL state: XX000
So it looks like there are at least to issues:
1. open rings
2. invalid number of points in ring
that are causing problems.
Thanks,
   -Steve
On 12/8/2011 1:25 PM, Paul Ramsey wrote:
> First confirm if PostGIS 1.5.3 is any better.
> If it's not, this should not be a major problem to fix.
> P.
> On Thu, Dec 8, 2011 at 10:15 AM, Stephen Woodbridge
> <woodbri at swoodbridge.com>  wrote:
>> This was loaded via:
>> ogr2ogr -t_srs EPSG:4326 out.shp in.shp
>> This complained about something but seems to have passed on at least some of
>> the problems.
>> shp2pgsql ...
>> No complaints there - so maybe this command should be extended to validate
>> geometry and have a rule for how to handle bad ones like NULL the geom or
>> try to fix it, etc.
>> I was able to locate the first issue, and after about 30 mins of trying this
>> and that was able to locate the bad record and dump with astext and manually
>> copy the start point  to an new end point and fix that.
>> The problem is I have 503 more records that are not valid and want to fix
>> them but the tools do not allow me to easily sort out the simple invalid
>> from the more severe ones because these commands are dying on fatal errors
>> instead of recognizing it is a fatal condition are reporting it
>> appropriately. :(
>> So my first need it to sort the simple and problematic cases. Any ideas on
>> this?
>> Thanks,
>>   -Steve
>> On 12/8/2011 12:17 PM, Paul Ramsey wrote:
>>> Somehow you've snuck an unclosed polygon into the system. They don't
>>> usually get in, because the parser disallows them.
>>> This will make dumping a test data tricky at best...
>>> P.
>>> On Thu, Dec 8, 2011 at 8:42 AM, Stephen Woodbridge
>>>> Hi all,
>>>> I'm getting this error:
>>>> select gid from parcels where not isvalid(the_geom);
>>>> ERROR:  pt_in_ring_2d: V[n] != V[0] (-83.5001 38.244 != -83.5001 38.244)
>>>> SQL state: XX000
>>>> isvalid(the_geom);
>>>> NOTICE:  IllegalArgumentException: Invalid number of points in LinearRing
>>>> found 3 - must be 0 or>= 4
>>>> SQL state: XX000
>>>> "POSTGIS="1.5.1" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.6.1, 21 August
>>>> 2008"
>>>> LIBXML="2.6.32" USE_STATS"
>>>> This just seems very bad in that isvalid() and st_isvalidreason() should
>>>> never fail, IMO.
>>>> -Steve
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
