[postgis-users] How to update your SVN copy of PostGIS
Aren Cambre
aren at arencambre.com
Sat Dec 10 06:47:17 PST 2011
Thanks. Yesterday I found *postgis_upgrade_20_minor.sql* in *
/usr/share/postgresql/9.1/contrib/postgis-2.0*.
When I ran that, I got tons of errors like this:
*psql:/usr/share/postgresql/9.1/contrib/postgis-2.0/postgis_upgrade_20_minor.sql:3235:
ERROR: current transaction is aborted, commands ignored until end of
transaction block*
I see you mentioned *rtpostgis_upgrade_20_minor.sql*. Isn't that just for
raster functions? I searched my machine and cannot find it, anyway.
Aren
On Fri, Dec 9, 2011 at 10:02 PM, Bborie Park <bkpark at ucdavis.edu> wrote:
> Aren,
> Since you're tracking trunk, after you've done the configure, make and
> make install, you'll want to run the upgrade script
> Usually, the file is installed in the same place as rtpostgis.sql. If
> you can't find the upgrade file, you can find it in your checkout's
> directory at:
> raster/rt_pg
> -bborie
> On Fri, Dec 9, 2011 at 7:53 PM, Aren Cambre <aren at arencambre.com> wrote:
> > Thanks. I got the latest SVN snapshot. I was able to configure, make, and
> > make install. The problem is there seems to be missing steps between
> > building the whole thing and getting changes into my preexisting
> > PostGIS-enabled database.
> > Aren
> > On Fri, Dec 9, 2011 at 9:47 PM, Bborie Park <bkpark at ucdavis.edu> wrote:
> >> If you used something like...
> >> svn check out https://svn.osgeo.org/postgis/trunk
> >> You can safely run...
> >> svn update
> >> If that works, I'd recommend doing...
> >> svn cleanup
> >> -bborie
> >> On Fri, Dec 9, 2011 at 7:19 PM, Aren Cambre <aren at arencambre.com>
> wrote:
> >> > I admit this is a dumb question, but here it is.
> >> > I installed PostGIS on my Ubuntu 11.10 environment a few weeks ago
> using
> >> > the
> >> > excellent instructions
> >> > at http://www.letseehere.com/postgis-geocoder-using-tiger-2010-data.
> >> > Since then, the geocode_intersection function was added, and I need
> it.
> >> > I'm
> >> > not clear what is the process of replacing the older snapshot of
> PostGIS
> >> > with this newer one.
> >> > I don't see an obvious install/uninstall routine. I tried the soft
> >> > upgrade
> >> > at
> http://postgis.refractions.net/documentation/manual-svn/postgis_installation.html#upgrading
> >> > but that didn't work. Do I need to do the hard upgrade each time I do
> a
> >> > SVN
> >> > update?
> >> > Aren
> >> > _______________________________________________
> >> > postgis-users mailing list
> >> > postgis-users at postgis.refractions.net
> >> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> >> Bborie Park
> >> Programmer
> >> Center for Vectorborne Diseases
> >> UC Davis
> >> 530-752-8380
> Bborie Park
> Programmer
> UC Davis
> 530-752-8380
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111210/48be768f/attachment.html>
