[postgis-users] How to update your SVN copy of PostGIS
Bborie Park
bkpark at ucdavis.edu
Fri Dec 9 20:02:19 PST 2011
Aren,
Since you're tracking trunk, after you've done the configure, make and
make install, you'll want to run the upgrade script
rtpostgis_upgrade_20_minor.sql
Usually, the file is installed in the same place as rtpostgis.sql. If
you can't find the upgrade file, you can find it in your checkout's
directory at:
raster/rt_pg
-bborie
On Fri, Dec 9, 2011 at 7:53 PM, Aren Cambre <aren at arencambre.com> wrote:
> Thanks. I got the latest SVN snapshot. I was able to configure, make, and
> make install. The problem is there seems to be missing steps between
> building the whole thing and getting changes into my preexisting
> PostGIS-enabled database.
> Aren
> On Fri, Dec 9, 2011 at 9:47 PM, Bborie Park <bkpark at ucdavis.edu> wrote:
>> If you used something like...
>> svn check out https://svn.osgeo.org/postgis/trunk
>> You can safely run...
>> svn update
>> If that works, I'd recommend doing...
>> svn cleanup
>> -bborie
>> On Fri, Dec 9, 2011 at 7:19 PM, Aren Cambre <aren at arencambre.com> wrote:
>> > I admit this is a dumb question, but here it is.
>> > I installed PostGIS on my Ubuntu 11.10 environment a few weeks ago using
>> > the
>> > excellent instructions
>> > at http://www.letseehere.com/postgis-geocoder-using-tiger-2010-data.
>> > Since then, the geocode_intersection function was added, and I need it.
>> > I'm
>> > not clear what is the process of replacing the older snapshot of PostGIS
>> > with this newer one.
>> > I don't see an obvious install/uninstall routine. I tried the soft
>> > upgrade
>> > at http://postgis.refractions.net/documentation/manual-svn/postgis_installation.html#upgrading,
>> > but that didn't work. Do I need to do the hard upgrade each time I do a
>> > SVN
>> > update?
>> > Aren
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Bborie Park
>> Programmer
>> Center for Vectorborne Diseases
>> UC Davis
>> 530-752-8380
Bborie Park
Programmer
UC Davis
530-752-8380
