[postgis-users] How to update your SVN copy of PostGIS
Aren Cambre
aren at arencambre.com
Fri Dec 9 19:53:11 PST 2011
Thanks. I got the latest SVN snapshot. I was able to* configure*, *make*,
and *make install*. The problem is there seems to be missing steps between
building the whole thing and getting changes into my preexisting
PostGIS-enabled database.
Aren
On Fri, Dec 9, 2011 at 9:47 PM, Bborie Park <bkpark at ucdavis.edu> wrote:
> If you used something like...
> svn check out https://svn.osgeo.org/postgis/trunk
> You can safely run...
> svn update
> If that works, I'd recommend doing...
> svn cleanup
> -bborie
> On Fri, Dec 9, 2011 at 7:19 PM, Aren Cambre <aren at arencambre.com> wrote:
> > I admit this is a dumb question, but here it is.
> > I installed PostGIS on my Ubuntu 11.10 environment a few weeks ago using
> the
> > excellent instructions
> > at http://www.letseehere.com/postgis-geocoder-using-tiger-2010-data.
> > Since then, the geocode_intersection function was added, and I need it.
> I'm
> > not clear what is the process of replacing the older snapshot of PostGIS
> > with this newer one.
> > I don't see an obvious install/uninstall routine. I tried the soft
> upgrade
> > at
> http://postgis.refractions.net/documentation/manual-svn/postgis_installation.html#upgrading
> > but that didn't work. Do I need to do the hard upgrade each time I do a
> SVN
> > update?
> > Aren
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Bborie Park
> Programmer
> Center for Vectorborne Diseases
> UC Davis
> 530-752-8380
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111209/8e32a1cf/attachment.html>
