[postgis-users] How to update your SVN copy of PostGIS
Bborie Park bkpark at ucdavis.edu
Fri Dec 9 19:47:02 PST 2011
If you used something like...
svn check out https://svn.osgeo.org/postgis/trunk
You can safely run...
svn update
If that works, I'd recommend doing...
svn cleanup
-bborie
On Fri, Dec 9, 2011 at 7:19 PM, Aren Cambre <aren at arencambre.com> wrote:
> I admit this is a dumb question, but here it is.
> I installed PostGIS on my Ubuntu 11.10 environment a few weeks ago using the
> excellent instructions
> at http://www.letseehere.com/postgis-geocoder-using-tiger-2010-data.
> Since then, the geocode_intersection function was added, and I need it. I'm
> not clear what is the process of replacing the older snapshot of PostGIS
> with this newer one.
> I don't see an obvious install/uninstall routine. I tried the soft upgrade
> at http://postgis.refractions.net/documentation/manual-svn/postgis_installation.html#upgrading,
> but that didn't work. Do I need to do the hard upgrade each time I do a SVN
> update?
> Aren
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
