[postgis-users] Tigerdata for AZ, AS and VI
Ravi ada
raviada at dobeyond.com
Mon Dec 12 20:25:26 PST 2011
Thanks Steve, That's what I thought too, I ran the 'install_missing_indexes"
function, it ran for a few minutes and returned 't'. I am assuming it ran
successfully. The performance is still same. I increased the work_mem to 4GB
in postgresql.conf. It is still not acceptable.
Leo/Regina, anything specific that you want me to verify on my system?
Performance is terrible, I can never finish geocoding 3million addresses
with this performance.
Any help is highly appreciated.
Thanks
Ravi Ada
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stephen
Woodbridge
Sent: Monday, December 12, 2011 9:04 PM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] Tigerdata for AZ, AS and VI
Hi Ravi,
I do not have this setup on my machine, but I am willing to hazard a guess
that you are missing an index, but then I have no idea which
one(s) that might be. Leo and Regina are probably the experts in this, so I
would look over their past posts on the geocoder. You might also look at the
load and prep scripts in svn and see if there is an index there that you do
not have on your tables.
Regards,
-Steve
On 12/12/2011 9:50 PM, Ravi ada wrote:
> In these examples, they used only 2GB memory and 3GHz machine but
> still achieved a blazing fast results. The same queries mentioned in
> the link taking 10 and even 100 times more time to query a particular
> address. I am using a 16GB, 6 Core AMD machine, dedicated to this
> process. I did the tuning on postgresql config file based on the
> recommendations. I am attaching my file here.. Please let me know if
> the tuning parameters look good.
> http://postgis.refractions.net/documentation/manual-svn/Geocode.html
> This query is supposed to take only (61ms) but on my machine is was
(734ms).
> SELECT g.rating, ST_X(g.geomout) As lon, ST_Y(g.geomout) As lat,
> (addy).address As stno, (addy).streetname As street,
> (addy).streettypeabbrev As styp, (addy).location As city,
> (addy).stateabbrev As st,(addy).zip
> FROM geocode('75 State Street, Boston MA 02109') As g;
> Thanks
> Ravi Ada
> Ravi ada
> Sent: Monday, December 12, 2011 7:05 PM
> To: 'PostGIS Users Discussion'
> Thank you Steve. I downloaded AZ files again and loaded fine but
> others are still the same problem. According to your explanation that
should be ok.
> I got the postgis database loaded for all states now. I have about 3
> mil addresses, may not all be normalized, which I am trying to batch
> geocode them. I am using the example mentioned in this link.
> http://www.postgresonline.com/journal/archives/181-pgscript_intro.html
> I am even using 100 as a batch, my update query is too slow. Its
> updating at
> 1500 per hour. That's too slow, I will never be able to finish them.
> I have 16GB RAM, and 7200 rpm disk partitioned to hold the postgres
> table spaces. I am not sure what makes it run faster. Anybody has done
> so many addresses before? What makes the performance go faster? I am
> attaching the query and query plan here. www.pastie.org/3008194
> Any help is appreciated.
> Thanks
> Ravi Ada
> Stephen Woodbridge
> Sent: Monday, December 12, 2011 8:50 AM
> On 12/12/2011 9:18 AM, Ravi ada wrote:
>> Hello All,
>> Has anyone experienced loading tigerdata into postgis database for
>> Arizona, American Samoa and Virgin Islands. I getting "*addr.dbf"
>> cannot find errors. All the other states are loaded fine. I tried to
>> download the shape files again thinking that they might have been
>> corrupted during the transmission, but even after that I am getting
>> the
> same error.
>> Any ideas?
> My download of Tiger has all the *addr* files for Arizona and I
> believe I have accessed them all without a problem.
> In general, the *addr* files are optional, and there are none for
> Guam, American Samoa and Virgin Islands.
> Typically if the county or county equivalent does not have roads with
> address ranges in it, then it will not have any *addr* files. So it is
> possible that a county in Arizona in say the desert might not have any
> address ranges and therefore not have that file, but looking at the
> list of counties in Arizona it looks like they all have those files.
> -Steve W
> postgis-users mailing list
