[postgis-users] Tigerdata for AZ, AS and VI
Greg Williamson
gwilliamson39 at yahoo.com
Tue Dec 13 10:37:16 PST 2011
Ravi --
Could you run this with "EXPLAIN ANALYZE ..." and post the results; that might give something of a clue as to what issues the planner is encountering.
Greg W.
----- Original Message -----
> From: Ravi ada <raviada at dobeyond.com>
> To: 'PostGIS Users Discussion' <postgis-users at postgis.refractions.net>
> Cc:
> Sent: Monday, December 12, 2011 8:25 PM
> Subject: Re: [postgis-users] Tigerdata for AZ, AS and VI
>T hanks Steve, That's what I thought too, I ran the
> 'install_missing_indexes"
> function, it ran for a few minutes and returned 't'. I am assuming it
> ran
> successfully. The performance is still same. I increased the work_mem to 4GB
> in postgresql.conf. It is still not acceptable.
> Leo/Regina, anything specific that you want me to verify on my system?
> Performance is terrible, I can never finish geocoding 3million addresses
> with this performance.
> Any help is highly appreciated.
> Thanks
> Ravi Ada
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stephen
> Woodbridge
> Sent: Monday, December 12, 2011 9:04 PM
> To: postgis-users at postgis.refractions.net
> Hi Ravi,
> I do not have this setup on my machine, but I am willing to hazard a guess
> that you are missing an index, but then I have no idea which
> one(s) that might be. Leo and Regina are probably the experts in this, so I
> would look over their past posts on the geocoder. You might also look at the
> load and prep scripts in svn and see if there is an index there that you do
> not have on your tables.
> Regards,
> -Steve
> On 12/12/2011 9:50 PM, Ravi ada wrote:
>> In these examples, they used only 2GB memory and 3GHz machine but
>> still achieved a blazing fast results. The same queries mentioned in
>> the link taking 10 and even 100 times more time to query a particular
>> address. I am using a 16GB, 6 Core AMD machine, dedicated to this
>> process. I did the tuning on postgresql config file based on the
>> recommendations. I am attaching my file here.. Please let me know if
>> the tuning parameters look good.
>> http://postgis.refractions.net/documentation/manual-svn/Geocode.html
>> This query is supposed to take only (61ms) but on my machine is was
> (734ms).
>> SELECT g.rating, ST_X(g.geomout) As lon, ST_Y(g.geomout) As lat,
>> (addy).address As stno, (addy).streetname As street,
>> (addy).streettypeabbrev As styp, (addy).location As city,
>> (addy).stateabbrev As st,(addy).zip
>> FROM geocode('75 State Street, Boston MA 02109') As g;
>> Thanks
>> Ravi Ada
>> Ravi ada
>> Sent: Monday, December 12, 2011 7:05 PM
>> Thank you Steve. I downloaded AZ files again and loaded fine but
>> others are still the same problem. According to your explanation that
> should be ok.
>> I got the postgis database loaded for all states now. I have about 3
>> mil addresses, may not all be normalized, which I am trying to batch
>> geocode them. I am using the example mentioned in this link.
>> http://www.postgresonline.com/journal/archives/181-pgscript_intro.html
>> I am even using 100 as a batch, my update query is too slow. Its
>> updating at
>> 1500 per hour. That's too slow, I will never be able to finish them.
>> I have 16GB RAM, and 7200 rpm disk partitioned to hold the postgres
>> table spaces. I am not sure what makes it run faster. Anybody has done
>> so many addresses before? What makes the performance go faster? I am
>> attaching the query and query plan here. www.pastie.org/3008194
>> Any help is appreciated.
>> Thanks
>> Ravi Ada
>> Stephen Woodbridge
>> Sent: Monday, December 12, 2011 8:50 AM
>> On 12/12/2011 9:18 AM, Ravi ada wrote:
>>> Hello All,
>>> Has anyone experienced loading tigerdata into postgis database for
>>> Arizona, American Samoa and Virgin Islands. I getting
> "*addr.dbf"
>>> cannot find errors. All the other states are loaded fine. I tried to
>>> download the shape files again thinking that they might have been
>>> corrupted during the transmission, but even after that I am getting
>>> the
>> same error.
>>> Any ideas?
>> My download of Tiger has all the *addr* files for Arizona and I
>> believe I have accessed them all without a problem.
>> In general, the *addr* files are optional, and there are none for
>> Guam, American Samoa and Virgin Islands.
>> Typically if the county or county equivalent does not have roads with
>> address ranges in it, then it will not have any *addr* files. So it is
>> possible that a county in Arizona in say the desert might not have any
>> address ranges and therefore not have that file, but looking at the
>> list of counties in Arizona it looks like they all have those files.
>> -Steve W
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
