[postgis-users] Encoding problem UTF-8
Richard Greenwood richard.greenwood at gmail.com
Wed Dec 14 20:52:50 PST 2011
Bob,
Before running ogr2ogr try setting:
   set PGCLIENTENCODING=LATIN1
Rich
On Wed, Dec 14, 2011 at 11:28 AM, Bob Pawley <rjpawley at shaw.ca> wrote:
> Hi
> I am attempting to import a dxf file to Postgis using ogr2ogr version 1.8
> running on Win 7.
> I get errors “invalid byte sequence for encoding "UTF8": 0xfe” using the
> following command in command prompt. Points and text are not being imported.
> set DXF_INLINE_BLOCKS=false&set DXF_MERGE_BLOCK_GEOMETRIES=false&&ogr2ogr
> --config DXF_ENCODING UTF-8 -f "PostgreSQL" PG:"host=localhost user=postgres
> dbname=IDW password=calgary0623" Water_Ex.dxf -nln Import_PID  -overwrite
> -skipfailures
> During research of this problem I came upon a suggestion to check with the
> Postgre list.
> Can anyone suggest a solution?
> Following are a few of the error messages.
> Bob
> LIST', '{1,1,1}', 0) RETURNING ogc_fid
> ERROR 1: INSERT command for new feature failed.
> ERROR:  invalid byte sequence for encoding "UTF8": 0xfe
> Command: INSERT INTO "import_pid" ("wkb_geometry" , "layer", "subclasses",
> "exte
> ndedentity", "entityhandle", "blockname", "blockscale", "blockangle") VALUES
> (Ge
> omFromEWKT('SRID=-1;POINT (0.003291735334244 -0.065895915915561)'::TEXT) ,
> 'MC-A
> TT', 'AcDbEntity:AcDbBlockReference', '     4 tag_rev1 t      1
> KEYTAG■C,10,0 RE
> V_ID■C,10,0 REVISION■C,3,0 REVISED_BY■C,10,0 REVISED_ON■C,14,0
> REV_TITLE■C,32,0
> REV_BY_APP■C,16,0 APPROVEDBY■C,10,0 PENDING■C,1,0 PEND_MAIL■C,10,0', '327A',
> '_A
> T_DIRLIST', '{1,1,1}', 0) RETURNING ogc_fid
> "exte
> (Ge
> 'MC-A
> TT', 'AcDbEntity:AcDbBlockReference', '     4 tag_rev2 t      1
> REV_ID■C,10,0 RE
> V_DETAIL■C,50,0 REV_INT■N,3,0', '327B', '_AT_DIRLIST', '{1,1,1}', 0)
> RETURNING o
> gc_fid
> postgis-users mailing list
Richard Greenwood
www.greenwoodmap.com
