[postgis-users] Encoding problem UTF-8
Bob Pawley rjpawley at shaw.ca
Thu Dec 15 08:59:16 PST 2011
Thanks Richard
That imported the blocks and text as far as viewing is concerned.
However, the text is part of the Linestring layer and not in the text column
of the Postgresql table.
Is this to be expected?
Is there some way of identifying the text?
Bob
-----Original Message-----
Sent: Wednesday, December 14, 2011 8:52 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Encoding problem UTF-8
Bob,
Before running ogr2ogr try setting:
   set PGCLIENTENCODING=LATIN1
Rich
On Wed, Dec 14, 2011 at 11:28 AM, Bob Pawley <rjpawley at shaw.ca> wrote:
> Hi
> I am attempting to import a dxf file to Postgis using ogr2ogr version 1.8
> running on Win 7.
> I get errors “invalid byte sequence for encoding "UTF8": 0xfe” using the
> following command in command prompt. Points and text are not being
> imported.
> set DXF_INLINE_BLOCKS=false&set DXF_MERGE_BLOCK_GEOMETRIES=false&&ogr2ogr
> --config DXF_ENCODING UTF-8 -f "PostgreSQL" PG:"host=localhost
> user=postgres
> dbname=IDW password=calgary0623" Water_Ex.dxf -nln Import_PID  -overwrite
> -skipfailures
> During research of this problem I came upon a suggestion to check with the
> Postgre list.
> Can anyone suggest a solution?
> Following are a few of the error messages.
> Bob
> LIST', '{1,1,1}', 0) RETURNING ogc_fid
> ERROR 1: INSERT command for new feature failed.
> ERROR:  invalid byte sequence for encoding "UTF8": 0xfe
> Command: INSERT INTO "import_pid" ("wkb_geometry" , "layer", "subclasses",
> "exte
> ndedentity", "entityhandle", "blockname", "blockscale", "blockangle")
> VALUES
> (Ge
> omFromEWKT('SRID=-1;POINT (0.003291735334244 -0.065895915915561)'::TEXT) ,
> 'MC-A
> TT', 'AcDbEntity:AcDbBlockReference', '     4 tag_rev1 t      1
> KEYTAG■C,10,0 RE
> V_ID■C,10,0 REVISION■C,3,0 REVISED_BY■C,10,0 REVISED_ON■C,14,0
> REV_TITLE■C,32,0
> REV_BY_APP■C,16,0 APPROVEDBY■C,10,0 PENDING■C,1,0 PEND_MAIL■C,10,0',
> '327A',
> '_A
> T_DIRLIST', '{1,1,1}', 0) RETURNING ogc_fid
> "exte
> VALUES
> (Ge
> 'MC-A
> TT', 'AcDbEntity:AcDbBlockReference', '     4 tag_rev2 t      1
> REV_ID■C,10,0 RE
> V_DETAIL■C,50,0 REV_INT■N,3,0', '327B', '_AT_DIRLIST', '{1,1,1}', 0)
> RETURNING o
> gc_fid
> postgis-users mailing list
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
