[postgis-users] Convert from character to timestamptz
Mathieu Basille basille at ase-research.org
Sun Dec 18 20:26:45 PST 2011
Le 18/12/2011 22:56, Mathieu Basille a écrit :
> Le 01/10/2011 03:02, Sandro Santilli a écrit :
>> On Fri, Sep 30, 2011 at 09:10:27PM -0400, Mathieu Basille wrote:
>>> Le 30/09/2011 17:49, Sandro Santilli a écrit :
>>>>> You're right, I'm being too vague (in my defence, error messages are
>>>>> in French for me!).
>>>> See if exporting LANG=C helps there.
>>> Did you mean at the command line or in the SQL query window? I tried
>>> both with no success.
>>> I also tried to launch pgAdmin with 'LC_ALL=C pgadmin3', but error
>>> messages were still in French. What's weird is that the whole
>>> software runs in English!
>> You probably need that variable to be in the backend environment, as
>> that's where the messages originate from. But a user-driven language
>> support would make much more sense so maybe it _is_ possible to do,
>> seek the web about it, there might be a way to signal the desired
>> language from the frontend to the backend (some set variable thing)
>> and if not you could file a feature request for pgsql hackers :)
> For the record (after a long silence): I managed to get error messages in
> English after doing the following (under Debian Wheezy):
> 1) edit the postgresql.conf
> # nano /etc/postgresql/8.4/main/postgresql.conf
> Look at the 'CLIENT CONNECTION DEFAULTS' section, 'Locale and Formatting'
> subsection, and change the 'lc_messages' variable:
> lc_messages = 'en_US.UTF-8'
Note, however, that 'en_US.UTF-8' has to be available first. Check it with:
$ locale -a
and install it if needed with:
# dpkg-reconfigure locales
(it will ask for the default locale for the system, which can be of course
different from the one used by PostgreSQL)
Mathieu.
> 2) restart the PostgreSQL server:
> service postgresql restart
> Now messages are in English. Example:
> $ psql -h localhost -d geodb -U caribou -q -c "blabla"
> ERROR:  syntax error at or near "blabla"
> LIGNE 1 : blabla
> All the best,
> Mathieu.
>>> ALTER TABLE test
>>>     ALTER COLUMN date TYPE timestamptz
>>>     USING date::timestamptz;
>>> I have now date as a 'timestamptz'!
>> Great !
>> --strk;
>>   ()   Free GIS & Flash consultant/developer
>>   /\   http://strk.keybit.net/services.html
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
~$ whoami
Mathieu Basille, Post-Doc
~$ locate
Laboratoire d'Écologie Comportementale et de Conservation de la Faune
+ Centre d'Étude de la Forêt
Département de Biologie
Université Laval, Québec
~$ info
http://ase-research.org/basille
~$ fortune
``If you can't win by reason, go for volume.''
Calvin, by Bill Watterson.
