[postgis-users] Raster pixel value
Tom van Tilburg
tom.van.tilburg at gmail.com
Mon Dec 19 02:14:07 PST 2011
Divisions by zero shouldn't happen as far as I know, at most it should
give you null data as return.
Sounds like a bug.
Perhaps you can check:
http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/plpgsql/st_summarystatsagg.sql
at line 69 it says: "($1).sum / ($1).count"
my guess is that that's where the division by 0 happens.
(it means probably that there is an empty raster somewhere in your
results that consequently leads to count() = 0 )
You can find the same code in your database functions ofcourse.
Good luck!
Tom
On 19-12-2011 10:53, Andreas Forø Tollefsen wrote:
> Updated to latest trunk, and now it works.
> However, I ran into a new "division by zero" error. This halts the query.
> Could it be that something is divided by integer rather than decimal
> in the query, or what else causes this:
> ERROR: division by zero
> CONTEXT: PL/pgSQL function "raster_summarystatsfinal" line 5 at
> assignment
> ********** Error **********
> SQL state: 22012
> Context: PL/pgSQL function "raster_summarystatsfinal" line 5 at assignment
> Best,
> Andreas
