[postgis-users] Raster pixel value
Andreas Forø Tollefsen
andreasft at gmail.com
Mon Dec 19 03:46:35 PST 2011
I also as you see tried to divide on 3600 as that was the possible number
of pixel count per geometry polygon (foo2.gid).
Andreas
2011/12/19 Andreas Forø Tollefsen <andreasft at gmail.com>
> Thanks Tom,
> I tried to select WHERE (ss).count > 0 and (ss).sum > 0, but i still got
> the same error. I assume that this is something that need to be changed in
> the script.
> I will do some more testing.
> Does anyone have an idea for something that could bypass this in my query?
> SELECT foo2.gid, (ss).sum / 3600 AS meanttime
> INTO accessgrid FROM (SELECT foo.gid, ST_SummaryStatsAgg(gv) ss
> FROM (SELECT p.gid, ST_Clip(r.rast, p.cell) gv FROM access r,
> priogrid_land p WHERE ST_Intersects(r.rast, p.cell)) foo
> GROUP BY foo.gid) foo2
> ORDER BY foo2.gid;
> Thanks!
> Andreas
> 2011/12/19 Tom van Tilburg <tom.van.tilburg at gmail.com>
>> Yes, well found.
>> I'm not familiar with plpgsql, but I'm sure it's easy to include some
>> conditional statement. Just check the postgres documentation.
>> You can also check if you can put the conditional into your SQL query
>> (something like 'WHERE count(rast) > 0') so that you don't feed empty
>> rasters to the function.
>> all the best,
>> Tom
>> On 19-12-2011 11:13, Andreas Forø Tollefsen wrote:
>> Line 59 to 77 in the st_summarystatsagg.sql.
>> Could it be that line 69: ($1).sum / ($1).count leads to division by zero
>> error if ($1).count is 0?
>> How could i change this so this is not the case?
>> -- raster_summarystatsfinal
>> -- Final function used by the ST_SummaryStatsAgg aggregate
>> CREATE OR REPLACE FUNCTION raster_summarystatsfinal(ss summarystats)
>> RETURNS summarystats
>> AS $$
>> DECLARE
>> ret summarystats;
>> BEGIN
>> ret := (($1).count,
>> ($1).sum,
>> ($1).sum / ($1).count,
>> null,
>> ($1).min,
>> ($1).max
>> )::summarystats;
>> RETURN ret;
>> END;
>> LANGUAGE 'plpgsql';
>>> Updated to latest trunk, and now it works.
>>> However, I ran into a new "division by zero" error. This halts the query.
>>> Could it be that something is divided by integer rather than decimal in
>>> the query, or what else causes this:
>>> ERROR: division by zero
>>> CONTEXT: PL/pgSQL function "raster_summarystatsfinal" line 5 at
>>> assignment
>>> ********** Error **********
>>> SQL state: 22012
>>> Context: PL/pgSQL function "raster_summarystatsfinal" line 5 at
>>> assignment
>>> Best,
>>> Andreas
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111219/56445b59/attachment.html>
