[postgis-users] Retrieve a feature having point coordinates
Alessandro Candini
candini at meeo.it
Tue Dec 27 01:37:30 PST 2011
Hi list.
I'm new to Postgis world and I have a probable dumb question:
I have a shape file inserted into a postgis database through shp2pgsql
utility and I would like to retrieve a feature ID giving as input a pair
of lat/lon coordinates.
Something like "SELECT gid from mytable WHERE point_is_into(45.2, 23.3);"
How can I achieve this?
Thanks in advance.
Alessandro Candini
MEEO S.r.l.
Via Saragat 9
I-44122 Ferrara, Italy
Tel: +39 0532 1861501
Fax: +39 0532 1861637
http://www.meeo.it
"ATTENZIONE:le informazioni contenute in questo messaggio sono
da considerarsi confidenziali ed il loro utilizzo è riservato unicamente
al destinatario sopra indicato. Chi dovesse ricevere questo messaggio
per errore è tenuto ad informare il mittente ed a rimuoverlo
definitivamente da ogni supporto elettronico o cartaceo."
"WARNING:This message contains confidential and/or proprietary
information which may be subject to privilege or immunity and which
is intended for use of its addressee only. Should you receive this
message in error, you are kindly requested to inform the sender and
to definitively remove it from any paper or electronic format."
