[postgis-users] Retrieve a feature having point coordinates
Alessandro Candini candini at meeo.it
Tue Dec 27 02:11:34 PST 2011
It dosn't work sayng to me the following:
ERROR:  Argument to X() must be a point
> Maybe you want to try it this way:
> SELECT gid,geom FROM mytable
> WHERE st_x(geom) >=45.19 AND st_x(geom) <=45.21
> AND st_y(geom) >=23.29 AND st_y(geom) <=23.31
> It finds all points in the given bounding box. But you cannot specify
> exactly one point, because there could be more than one at this point.
> Hope that helps although.
> Cheers.
> 2011/12/27 Alessandro Candini <candini at meeo.it <mailto:candini at meeo.it>>
>     Hi list.
>     I'm new to Postgis world and I have a probable dumb question:
>     I have a shape file inserted into a postgis database through
>     shp2pgsql utility and I would like to retrieve a feature ID giving
>     as input a pair of lat/lon coordinates.
>     Something like "SELECT gid from mytable WHERE point_is_into(45.2,
>     23.3);"
>     How can I achieve this?
>     Thanks in advance.
>     Alessandro Candini
>     MEEO S.r.l.
>     Via Saragat 9
>     I-44122 Ferrara, Italy
>     Tel: +39 0532 1861501 <tel:%2B39%200532%201861501>
>     Fax: +39 0532 1861637 <tel:%2B39%200532%201861637>
>     http://www.meeo.it
>     "ATTENZIONE:le informazioni contenute in questo messaggio sono
>     da considerarsi confidenziali ed il loro utilizzo è riservato
>     unicamente
>     al destinatario sopra indicato. Chi dovesse ricevere questo messaggio
>     per errore è tenuto ad informare il mittente ed a rimuoverlo
>     definitivamente da ogni supporto elettronico o cartaceo."
>     "WARNING:This message contains confidential and/or proprietary
>     information which may be subject to privilege or immunity and which
>     is intended for use of its addressee only. Should you receive this
>     message in error, you are kindly requested to inform the sender and
>     to definitively remove it from any paper or electronic format."
>     _______________________________________________
>     postgis-users mailing list
>     postgis-users at postgis.refractions.net
>     <mailto:postgis-users at postgis.refractions.net>
>     http://postgis.refractions.net/mailman/listinfo/postgis-users
Alessandro Candini
MEEO S.r.l.
Via Saragat 9
http://www.meeo.it
da considerarsi confidenziali ed il loro utilizzo è riservato unicamente
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111227/93737ee6/attachment.html>
