[postgis-users] Using PostGIS in commercial application
Josh Jordan
joshjordan at robotjosh.com
Wed Dec 28 06:52:05 PST 2011
It would be more clear if your architecture only used postgis to serve data
to a non-postgis client application. Maybe you can use postgis this way
without providing your custom patches.
On Wed, Dec 28, 2011 at 7:10 AM, Greg Troxel <gdt at ir.bbn.com> wrote:
> From: Josh Jordan <joshjordan at robotjosh.com>
> I think it should be ok as long as you open source any custom patches in
> the postgis that you distribute.
> This doesn't make sense - that would be for LGPL, more or less.
> Certainly one has to provide the source to the GPL component, modified
> or not, and regardless of bundling. Perhaps you meant that the bundling
> is not distribution, but the GPL obligations on the underlying postgis
> distribution remain, in which case I think we agree.
> The question is whether the entire installer is a derived work under
> copyright law. If it is, then the GPL components may not be distributed
> unless the entire bundle is offered under the GPL. Answering te
> is-it-a-derived-work question is close to impossible, depends on one's
> jurisdiction, and requires an IP lawyer who understands open source
> licensing.
> There's a further subtlely, which is whether code that uses postgis's
> interfaces is a derived work. This sort of claim is made for Linux
> kernel modules. But, generally no one claims that talking regular SQL
> results in a derived work (partly because it's a standard), and this
> issue seems to be mostly limited to compilation of modules/plugins
> against GPL-licensed headers. But something else to discuss with
> counsel :-)
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111228/9c1d4f02/attachment.html>
