[postgis-users] postgis removed from latest postgres' stack builder?
Andreas Neumann
a.neumann at carto.net
Wed Dec 28 23:30:57 PST 2011
Postgis is not limited to 32bit - however, on Windows, the existing
1.5x installers only work properly in the 32bit version of PostgreSQL. I
guess there are no technical reasons for this limitation, just a
packaging issue. I think Postgis 2.0x will also ship in 64bit versions
on Windows.
So if you are on 64bit Windows, you should install 32bit PostgreSQL
with the spatial extensions.
Andreas
On Wed, 28 Dec 2011 21:53:51 -0600, Aren Cambre wrote:
> Did you install the 64 bit version? PostGIS is 32 bit only.
> Aren
> On Wed, Dec 28, 2011 at 9:37 PM, Daniel Montenegro wrote:
>> Why there isn't anymore the field SPATIAL EXTENSIONS (wich have
>> postgis) in the latest version of Postgres' STACK BUILDER? This is
>> weird... I mean, I had to download an older version of Postgres to
>> be able to install Postgis.
>> I really think this should be fixed.
>> Thanks,
>> Daniel
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net [1]
>> http://postgis.refractions.net/mailman/listinfo/postgis-users [2]
> Links:
> [1] mailto:postgis-users at postgis.refractions.net
> [2] http://postgis.refractions.net/mailman/listinfo/postgis-users
> [3] mailto:dmontenegro84 at gmail.com
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
