[postgis-users] postgis removed from latest postgres' stack builder?
Bborie Park
bkpark at ucdavis.edu
Thu Dec 29 07:45:45 PST 2011
For Windows, only 32-bit PostGIS builds have been built successfully
(mingw). There are a variety of issues preventing a successful build
of 64-bit (dependencies and other strange errors).
Personally, I've yet to be able to successfully compile 32-bit PostGIS
2.0 (currently trunk) and haven't had time (nor patience) to figure
out the problems.
-bborie
On Wed, Dec 28, 2011 at 11:30 PM, Andreas Neumann <a.neumann at carto.net> wrote:
> Postgis is not limited to 32bit - however, on Windows, the existing 1.5x
> installers only work properly in the 32bit version of PostgreSQL. I guess
> there are no technical reasons for this limitation, just a packaging issue.
> I think Postgis 2.0x will also ship in 64bit versions on Windows.
> So if you are on 64bit Windows, you should install 32bit PostgreSQL with the
> spatial extensions.
> Andreas
> On Wed, 28 Dec 2011 21:53:51 -0600, Aren Cambre wrote:
>> Did you install the 64 bit version? PostGIS is 32 bit only.
>> Aren
>> On Wed, Dec 28, 2011 at 9:37 PM, Daniel Montenegro wrote:
>>> Why there isn't anymore the field SPATIAL EXTENSIONS (wich have
>>> postgis) in the latest version of Postgres' STACK BUILDER? This is
>>> weird... I mean, I had to download an older version of Postgres to
>>> be able to install Postgis.
>>> I really think this should be fixed.
>>> Thanks,
>>> Daniel
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net [1]
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users [2]
>> Links:
>> [1] mailto:postgis-users at postgis.refractions.net
>> [2] http://postgis.refractions.net/mailman/listinfo/postgis-users
>> [3] mailto:dmontenegro84 at gmail.com
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
