[postgis-users] postgis removed from latest postgres' stack builder?
Aren Cambre aren at arencambre.com
Thu Dec 29 12:14:11 PST 2011
Oops, yes, I was talking about the Windows version.
Aren
On Thu, Dec 29, 2011 at 1:30 AM, Andreas Neumann <a.neumann at carto.net>wrote:
> Postgis is not limited to 32bit - however, on Windows, the existing 1.5x
> installers only work properly in the 32bit version of PostgreSQL. I guess
> there are no technical reasons for this limitation, just a packaging issue.
> I think Postgis 2.0x will also ship in 64bit versions on Windows.
> So if you are on 64bit Windows, you should install 32bit PostgreSQL with
> the spatial extensions.
> Andreas
> On Wed, 28 Dec 2011 21:53:51 -0600, Aren Cambre wrote:
>> Did you install the 64 bit version? PostGIS is 32 bit only.
>> Aren
>> On Wed, Dec 28, 2011 at 9:37 PM, Daniel Montenegro  wrote:
>>  Why there isn't anymore the field SPATIAL EXTENSIONS (wich have
>>> postgis) in the latest version of Postgres' STACK BUILDER? This is
>>> weird... I mean, I had to download an older version of Postgres to
>>> be able to install Postgis.
>>> I really think this should be fixed.
>>> Thanks,
>>> Daniel
>>> ______________________________**_________________
>>> postgis-users mailing list
>>> postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>[1]
>>> http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>[2]
>> Links:
>> [1] mailto:postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>> [2] http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
>> [3] mailto:dmontenegro84 at gmail.com
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111229/02e7667b/attachment.html>
