[postgis-users] How to configure Postgis/Postgresql to use with QGIS
Daniel Montenegro dmontenegro84 at gmail.com
Thu Dec 29 07:54:38 PST 2011
Thanks Sindile and Brent,
Actually, I've unnistalled Postgres (the latest version - 9.xx) and
downloaded an older one (8.1.4 - I guess). Then I used STACK BUILDER to
install PostGIS on Postgres.
Now let me ask you something else:
Supose that I have a polygon shape - like "MyCyty.shp", how can I export it
to Postgres *via* Postgis. I tryed to use the SPIT plugin from QGIS but
isn't working right yet... Do I have to create some spatial database in
Postgres before trying to export it in QGIS?
Thanks a lot!
Daniel
P.S.: I'm using PGADMIN.
2011/12/29 <pcreso at pcreso.com>
>   Hi Daniel,
> The docs are a good place to start, but here is the simple version, from
> the command line...
> If you have got Postgres installed OK, you need to create a new database,
> then install Postgis into it, so I'm assuming you have a working Postgres
> superuser account you can use.  Then:
> # create the new, empty database
> createdb test_gis
> # add support for the plpgsql language. Not always needed for v9+ of
> Postgres, but it # won't hurt anything to try it anyway.
> createlang test_gis plpgsql
> # find where on your system the postgis.sql & spatial_reference_sys.sql
> files are
> # run these in your new database
> psql -d test_gis -f postgis.sql
> psql -d test_gis -f spatial_ref_sys.sql
> # You now have a working Postgis database.
> # connect to the database
> psql -d test_gis
> # create a simple table there. QGIS likes integer primary keys, this gives
> it one
> create table test_tab (id serial primary key, name varchar(12));
> # add a lat/long geometry column to the table
> select addgeometry('','test_tab','geom',4326,'POINT',2);
> # add a couple of points to the table
> insert into test_tab values (default,'point 1',ST_setsrid(makepoint(179,
> -45),4326));
> insert into test_tab values (default,'point 2',ST_setsrid(makepoint(179.2,
> -45.2),4326));
> # see that they exist:
> select * from test_tab;
> select id, name, ST_astext(geom) as geom from test_tab;
> # exit postgres
> \q
> To open the table & see the points plotted in QGIS you have a bit of
> configuration to do. By default a Postgres database is installed securely,
> so external applications & remote computers cannot connect to it.
> The instructions here open the database up to anyone, so it is pretty
> insecure. If you want to address this, read the Postgres docs...
> Shut down your Postgres server. How you do this depends on your operating
> system & version.
> find the file "pg_hba.conf". It contains the access settings.
> edit this (you may need admin rights) & set all users from all IP
> addresses for all databases to "trust", as described in the file
> find the file postgresql.conf
> edit this & set "listen_addresses" to "*" as described in the file ( = all)
> restart the Postgresql service, it will now have an open access
> configuration, as you just specified.
> You can now fire up QGIS on a local or remote system & connect to the
> database test_gis on the specified server (if same system as the database,
> the host is called localhost). QGIS will show you the table test_tab &
> adding this should show your two points.
> HTH,
>   Brent Wood
> --- On *Thu, 12/29/11, Daniel Montenegro <dmontenegro84 at gmail.com>* wrote:
> From: Daniel Montenegro <dmontenegro84 at gmail.com>
> Subject: [postgis-users] How to configure Postgis/Postgresql to use with
> QGIS
> To: postgis-users at postgis.refractions.net
> Date: Thursday, December 29, 2011, 2:37 PM
>  Hi there!
> I've installed Postgis but I'm not being able to create a "spatial" table
> with a geometry column in Postgresql. Actually, I think I still didn't get
> all the steps to configure postgis in postgresql.
> I really need some help!
> Thanks a lot,
> Daniel
> -----Inline Attachment Follows-----
> postgis-users mailing list
> postgis-users at postgis.refractions.net<http://mc/compose?to=postgis-users@postgis.refractions.net>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111229/9511b0db/attachment.html>
